メインコンテンツにスキップ
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
139回答 すべてを表示
Starter or solenoid problem?
My 2003 Chevy Cavalier will not start. When I turn the key there is nothing. All the lights and the power windows work. The battery tested good. How can I tell if this is a starter problem or a solenoid. There is no clicking or any sound when turning the key.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
knightflee, you can check the starter by jumping the solenoid. Check this video at around 1.00" to see where to apply the jump. If it works you know your starter is okay but are having issues with the solenoid circuit. when you do this, make sure that your parking brake is applied, that you are not in gear etc. You do not want to run yourself, or anybody else over. Here is some great information on how to check the circuit.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
oldturkey03 Thank you very much for the video. It was very helpful.
さんによる
Thanks very helpful
さんによる
コメントを追加
回答を追加する
knightflee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 4,673
