メインコンテンツにスキップ
The Panasonic Lumix DMC-TZ5 was released March, 2008. It is the third camera in the TZ series, with a 3.0 inch viewing screen, 28-280 lens (10x optical zoom) and 9.1 megapixels. The TZ5 also has 720p HD video recording.
lens error-message-please turn camera off and on again
When turning camera ON, all appears normal for a few seconds, then the ERROR MESSAGE "PLEASE TURN CAMERA OFF AND THEN TURN ON AGAIN".
When turning OFF, the lens stays out.
When turning back ON, the lens retracts, then extends and stays out, and the process repeats. (The shutter does not work during the few seconds that operation appears NORMAL.)
I've replaced the battery with a fully-charged one. No difference in operation.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
It sounds like the lens is jamming. You might have some physical damage, some debris in the gears or mechanism, or it's just worn out. You could try taking it apart and cleaning out the gunk. Good luck, but you will probably end up buying a new, better camera.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
jhkmtk44 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 2,397
