メインコンテンツにスキップ
2.0GHz, 2.3GHzもしくは2.6GHzクアッドコアIntel Core i7プロセッサ (Turbo Boost 最大3.8GHz) 6MB共有L3 キャッシュ付き。
580回答 すべてを表示
MacBook not turning on after screen replacement. Orange light on charg
Hi,
I have a Macbook Pro Retina Late 2013 A1398 EMC 2674. I broke my retina display and replaced it with a brand new display assembly (lid, led, camera etc)
So before the display assembly replacement, The macbook was running I could see my login screen even tough the LED was broken.
I turned the Mac off, disconnected the battery and changed the display assembly.
Now for some reason its not turning on, the charger light is orange.
Thank you in advance for your answers.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
P.S I have tried shorting Pin 5 to ground but nothing happens, Just left it on charge for the time being and its still displaying the orange light.
さんによる
I tried SMC and PRAM reset, the magsafe 2 charger connector went green for a short time before turning back to amber.
Still on charge at the moment, btw I forgot to mention that I am using a aftermarket charger.
Regards
さんによる
コメントを追加
1 件の回答
Disconnect all the connectors for backlight and picture. Then try to turn your Mac on. This should help you troubleshoot and get down to what the problem is (lcd or logic board). And I have powered on my MBP w/o a screen attached before. With connecting a monitor via hdmi, I seen mine boot to the login screen.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mbaig さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 268
