メインコンテンツにスキップ
Originally released in 2006, the NeatDesk is a desktop document scanner with ADF and full-duplex features. The early revision has model number "ADF-070108" and the newer revision is model "ND-1000."
2 inch verticle line down center of page
I get a 2 inch vertical line down the center of the page on my Neat desk desktop scanner.
Any fixes or where I can get fixed?
Thanks!
Dave
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
2 件のコメント
I get a 1/2" vertical line that's blank towards the right side of pages that are full size. Smaller receipts are okay.
さんによる
Since it took so long to figure this out I tossed out the machine about 4 months ago. I repurchased the handheld version and now I'm having the same problem. Unfortunately, there doesn't seem to be a way of opening this model to do this. Thus, is there any way to open this model and complete this process?
さんによる
コメントを追加
6件の回答
最も参考になった回答
I am experiencing the following issue: "Double-sided scanning always produces a stray vertical line that runs for the entire length of the backside of a scanned image. "
The folks at Neat suggested the following:
''First, let's go through the cleaning process. Please select the link below for your model scanner and follow the steps provided.
For Neat Desk click here
http://www.neat.com/helpcenter/cleaning-...
For NeatMobile click here:
Next, you will want to calibrate the scanner with a sheet of plain white printing paper or the provided calibration paper.
To calibrate your scanner:
Open Neat, connect your scanner and click Tools>Scanner>Calibrate in the top right corner of your screen.
*Note: Please follow the onscreen instructions on calibrating your scanner.
Once the scanner has been successfully calibrated, please try scanning once more.
(Mobile Scanner - Scan with the image you would like to capture face down.)
(Desktop Scanner - Scan with the image you would like to capture face up, facing towards you)''
The problem still persists, so I am inclined to think that there is a mechanical issue related to the roller on the left-side of my desktop scanner. Not sure what to do next.
Larry Carrillo
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I have the same problem except 2 inches of the left side of the document is fuzzy and grey
さんによる
my front page has a two-three inch blank column down center of page. Please help!
さんによる
Same problem as Peter Miles, except 2 inches of the right side of the document is fuzzy and grey
さんによる
Thank You Larry, this was very helpful and your guidance resolve my problems.
さんによる
コメントを追加
1. open scanner
2. at bottom of scanner there are two plastic films on either side of the bottom of scanner.
3. get some nail varnish remover(100% acetone)
4. apply to lens cleaner cloth (eye glass cloth cleaner)
5. apply acetone to cloth then wipe gently across the two plastic films on bottom of machine.
6. apply until no more dirt lifts off. allow to evaporate(dry)
7. calibrate machine
8. clean machine
9. problem should be fixed clear scans. it worked for me
9
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Its a software issue. You have to buy the subscription by paying a monthly charge of mim $13.00
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
さんによる
Thanks! For the amount of time I use the scanner vs the number of scans I do per month, it's not worth $13/month.
I've moved on to a company that will sell me software the old fashioned way -- actually selling it to me, not dipping into my wallet every month.
さんによる
コメントを追加
Same issue. Doesn't fix it. Not sure what to do. Is it time to throw it out? What's the deal?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine was doing the same thing and I cleaned and cleaned and clean with no result. Finally I decided to gently lift up the 1/2" piece of plastic that covers the front of page scanning glass and ran my finger of all things (I had just washed and dried my hands so no oil build up) down the length of the plastic and noticed some dust had built up on my finger by doing so. This was a bit tricky because that plastic cover fits tight against the glass. THAT is what finally fixed my line issue.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thanks for the advice but I cannot figure out which piece of plastic your are referring to.  Can you take a photo or describe more specifically.  I cannot seem to lift up the plastic covers on the horizontal glass bar.  Is it the cover over the bar on the base of the machine or on the cover of the machine.  Thanks
さんによる
I did figure out what piece of plastic that you were referring to and cleaned it. It did have dust buildup on it bu did not fix my problem. My front page has a 3 inch blank column down center of page.
さんによる
I am experiencing the same issue. I have cleaned my scanner to the point it looks brand new. That flimsy piece of plastic Chris is referring to is above the large roller. It is actually attached to a removable piece that unhinges when you squeeze the two tabs next to the divots at the base of the large roller. I thoroughly cleaned everything. The grey markings that are on this particular scan seem to be of a different quality than markings from dirt scans i have had in the past. It makes me wonder if it is a software issue?
さんによる
コメントを追加
I have a Neat Desktop scanner running Neat’s 5.7 desktop software under Windows 10. I have an interesting issue.
If I scan a document, the post-scan image shows a 2” - 3” band running top-to-bottom along the left hand side of every page.
Here’s the interesting twist …
My Neat scanning software defaults to assuming whatever document is being scanned is a RECEIPT. So,
  1. Place document in scanner
  2. Click SCAN
  3. Document scans, processes and is imported into the “Documents” folder.
  4. Click on the scanned document,
  5. Image is clear.
  6. “Type” dialog box has defaulted to RECEIPT.
  7. Click on “Type” and change the document type to DOCUMENT.
  8. Screen refreshes.
  9. Refreshed image shows a 2” to 3” band running top-to-bottom along the left side of the image.
  10. Switch “Type” back to RECEIPT.
  11. Screen refreshes.
  12. Refreshed image shows a clean document - no band.
Then, I tried this:
  1. Before scanning document, change “type” to DOCUMENT.
  2. Scan document.
  3. Image shows a 2” to 3” band top-to-bottom along the left side of the document.
  4. Click on “Type” and change the document type to RECEIPT.
  5. Screen refreshes.
  6. Refreshed image shows a 2” to 3” band running top-to-bottom along the left side of the image.
  7. Switch “Type” back to DOCUMENT.
I’ve followed the cleaning and re-calibration procedures as provided by Neat, and I did the extra cleaning procedures you all suggested, then re-calibrated.
The first scan after re-calibration comes through clean, but the 2” to 3” band reappears on subsequent scans.
Suggestions? Software setting issue? Or, is this scanner toast?
Thanks!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David Pamintuan さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 30
過去 30 日: 83
今までの合計 8,411
