Why is my screen not working all the way
When I push power......dell logo shows and than screen stays black and doesn't go to home screen
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try a hard reboot or reset . This is done by removing the battery and disconnecting the power cord so there is no power to the laptop from any source. now hold down the power button for a full 60 seconds. This should discharge the cmos battery and clear the memory. Now put the battery back in plug in your computer and fire it up . Hope this helps .
このアンサーは役に立ちましたか?
I had a similar problem earlier this week.
I opened up the system, check some of the connections related to the monitor (unplugged and plugged back in). Closed it up, turned it on, and it runs great.
Sometimes a connection is just a bet loose.
I would try Jimfixer's suggestion first, as it is less labor intensive.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 3
過去 30 日: 6
今までの合計 579
