メインコンテンツにスキップ
The Toshiba Satellite M45 Laptop is designed for powerful, portable, multimedia computing. It features a 15.4” WXGA Display running Microsoft Windows XP, with 1.6GHz Processor, 512MB RAM, and 80GB Hard Drive.
13回答 すべてを表示
How to verify connection of USB ports & S-Video port to motherboard?
Is it possible to open only the rear panel of this laptop model S269 and check the motherboard connections to S-Video port and the 2 USB ports above the DVD drive?
I had tried to open the rear panel and when failed to do, fixed it back but since then, the ports mentioned above are not working.
Your suggestions would be greatly appreciated.
Thanks,
Rupesh
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
選択されたソリューション
according to the board layout on page 226 the usb and the s-video connector are in the same area of the motherboard - so most likely you disconnected (or broke) something in that area
the connection shoul be on the back- or bottom side of the motherboard
the service manual can be found here: CLICK
you can also use this service manual to correctly disassemble the notebook
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rupesh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 567
