メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
iPhone 5 no longer powers on or connects after dock replacement.
After replacing the dock of my iPhone, my iPhone 5 can no longer be charged or connected to a computer. It can however, play audio to the headphones and record audio from the microphone, so the cable which connects to the logic board is at least partially working. I have verified that the batter can be charged in another iphone 5. Is there any way I can troubleshoot with a voltmeter to see where the problem is?
I tried replacing this dock with another, and no luck, I have also made sure the cable works as well. I have compared photos of the connector on the logic board itself, and can see no damage, I have some photos here - http://imgur.com/a/Ieqz5
After a little searching, it looks like the IC U2 could be the problem, is there anyway I could verify this?
Thank you for your help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Most likely sounds like the U2 IC, especially if multiple docks have not changed the issue.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Is it possible that I could have damaged the U2 IC while replacing the dock? Looking at the location of it, it seems to be nowhere near the area where I was working, and also underneath another part.
さんによる
No, the U2 IC is the primary problem. The dock flex never was the issue.
さんによる
Considering charging and connecting working completely before I replaced the dock, I don't see how this is possible
さんによる
Then why did you replace the dock to begin with?
さんによる
Because I originally had problems with my headphone jack and microphone.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 87
