メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Home button functionality not working
Started as home button not clicking unless you pressed hard enough to distort the LCD but the fingerprint worked fine. I harvested three other buttons with success of the home button clicking. Now the touch ID doesn't work on any of the harvested buttons. It's like 1 step forward 1 step back. What are you thoughts? I am curious to hear what other techs have to say about this similar but different issue. I put the original button in which doesnt click and turned assistive touch on, even with assistive touch on the home button still doesnt work using that function. This is a strange bird :O
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Does the button click when not in the screen? If so, try loosening the screws where the home button plate goes in as it gives space sometimes, this is usually with third party screens.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The iPhone 5S home button is linked to the original motherboard it came with. If you replace the home button, you will no longer have Touch ID functionality. There is no getting around that, unless you pay Apple to replace it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have seen some posts saying its part of the board and also part of the charge pot area. The button clicks but it's not being recognized. I've talked to other tech that have successfully harvested and replaced buttons. Keep the info coming hopefully we can nail it down.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
frank さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 117
