メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
How to find out if my cellular antenna is damaged for sure?
I have this "searching..." error and tried everything already..! The only possible fix is to replace the cellular antenna, since I dropped the phone a lot of times and I heard that this could cause my problem too. However, is there any way to check if the antenna is really damaged or broke before I go and waste my money for nothing?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Just a suggestion but sometimes its not the antenna but the SIM card from the carrier that has gotten dislodged or messed up somehow, maybe a droplet or water perfectly landed on the door to it, or whatever, might check that first since it the easiest then, if your cell carrier doesn't use SIM cards then disregard this message
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
thanks for your answer! I checked that too... with a second (and 100% functioning) SIM-card but it didn't solve the problem... But once I did a hard reset and I got signal for 10 minutes but then it went back to "searching..." again..! :/
さんによる
コメントを追加
Adam Kustrio - I have an iPhone SE. It fell off a counter I have that might be 3 foot high. After that, I wasn't able to call out or receive calls. I took it to the T-Mobile store, they exchanged the SIM card, and that didn't work. (Same situation) - they suggested calling the claim number to report the antenna is messed up, and to ask for an exchange (since my phone isn't paid off yet). I shall see!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Adam Kustrio さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 16
過去 30 日: 64
今までの合計 15,774
