メインコンテンツにスキップ
Repair guides and support for top and front loading Whirlpool brand washers.
425回答 すべてを表示
Washer stopped in middle of cycle
It is on the rinse cycle but won't drain old water out?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Do you have power on the machine? Any code blinking? Can you advance the program?
さんによる
Yes it has power. It is not digital so can't program. If I put it on rinse or spin cycle it does nothing. If I put it back in wash cycle it will rotate
さんによる
Stacey, what model is your washer?
さんによる
コメントを追加
3件の回答
最も参考になった回答
Stacey, when a washing machine won't drain, there's is always a possibility that the drain filter is clogged. The drain filter is designed to catch lint, stuff left in pockets and all the other things that find their way into the washer (even socks etc:-) Your Whirlpool washer may have a drain pump filter. If so they are usually easily to access and check it. Before you go to check the filter, take a look at the drain hose behind the washer to ensure it isn't kinked or otherwise obstructed.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
washer stopped in the middle of cycle door is locked light keeps flashing , its not doing any thing else . Ineed my clothes .help,
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Tried that, still no opening
さんによる
コメントを追加
My whirlpool did the same thing so I replaced the door lid switch. It cost me less than $10 on eBay, I then watched a video on you tube on how to do it and it was a 10 minute job, good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stacey さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 6,091
