メインコンテンツにスキップ
2011年10月24日発売 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405回答 すべてを表示
締切られた回答
Coffee Damaged MacBook Pro Intermittently Powers On Via Power Adaptor
I dumped a whole cup of coffee (with lots of half & half) on my late 2011 MacBook Pro. After I cleaned it up and let it dry, it worked for a few days. Then I powered it down once and the power button wouldn't turn it back on. Yet it still accepts a charge from the power adapter.
I took the bottom panel off and let it air out for a couple more weeks. Here's where it gets weird. I then plugged it back into the wall and it magically booted up and worked like a champ. I then shut it down and again it failed to boot, but still acts like it's charging.
I deduce this to mean:
1. Logic board, RAM, HD, etc. are fine!
2. Battery must have been dead and automatically powers up when connected to power (can anyone confirm this functionality?).
3. The power button or something in that process is fried or has coffee and creamer gumming up the works.
Can anyone suggest what parts I might need replacing?
Thanks!
-J
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I removing and cleaned the logic board, battery, hard drive, optical drive and both fans. It was fun and I removed years of lint from the fans. I also cleaned the power button. Anyways, it didn't change anything.
It looks like I'll need to replace the upper case. There are a few dead keys on the keyboard in addition to the dead power button.
Read more from this answer from a similar question.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 82
