Is there a difference in replacing screen on wifi and LTE versions
Is there a difference in replacing screen on wifi and LTE versions. Is there a difference how the antennas are connected to the screen/front glass or something I should be aware of?
The digitizer (glass) is the same, but the lcds are different, so if replacing the lcd, make sure you get the correct one for your model of ipad mini.
このアンサーは役に立ちましたか?
Just be careful to not damage the antennas while you're disassembling it. They're known for breaking when jabbed with your choice of pry-poke tools and they like to stick to the glass so when someone pulls on the glass, they rip the data antennas out of the ipad
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 10
今までの合計 517
