Where can I buy the Power Supply?
That is. Where can I buy the Power supply? And, ti be sure o what I'm buying, is there any serial number or supply number? Thank you, Fabrizio
If you have the 1.8GHz then you need this one, if you have the 2.0GHz then you need this one. You can use this guide to install it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,384
