メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月に発表され、同年4月10日に発売されました。Galaxy S6 Edgeは Samsungの最新のスマートフォンで曲面ディスプレイをもつデバイスです。
Can I get samsung s6 edge to come out of ODIN MODE?
My phone will not switch on. I have tried to press the volume up + power + home key and also volume down + power + home key. My phone only goes to a blue page which says 'warning.. A customised os can corrupt your phone etc...' and 'press up to download' or 'down key to cancel and restart phone'. When I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key it will turn to a page saying downloading and will stay stuck on this page for hours. I have tried a number of combinations but nothing has worked. I cannot plug into a computer or go into samsung as I am on vacation on an island. I also cannot pull the battery out as I have a s6 edge and if I do unscrew it will void my warranty. Can anyone please help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 24
12 件のコメント
after hard reset my device goes into odin mode and restart what i do
さんによる
I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key .
さんによる
My phone will not switch on. I have tried to press the volume up + power + home key and also volume down + power + home key. My phone only goes to a blue page which says 'warning.. A customised os can corrupt your phone etc...' and 'press up to download' or 'down key to cancel and restart phone'. When I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key .
さんによる
whay if i disable usb seeting on my phone then also the reset factory and the laucher of the phone and its system UI shut down automatically ..how can i fix this please help me.. :(
さんによる
maybe my chace is on with ODIN mode but don't how .. please help me lol
さんによる
7件以上のコメントを表示
コメントを追加
12件の回答
ベストアンサー
Press all buttons at the same time and hold them.
このアンサーは役に立ちましたか?
スコア 154
58 件のコメント:
Thank you mine was stuck in this mode and I'm fairly new to the android world and this saved my butt majorly!!!
さんによる
love you brother thanx a ton
さんによる
Wow thanks man
さんによる
thanks man, saved me
さんによる
worked for me nice one dude
さんによる
53件以上のコメントを表示
コメントを追加
Just hold all the Buttons on the same time power button volume up volume down and home button
このアンサーは役に立ちましたか?
スコア 22
1件のコメント:
my power button is stuck and doesn't work
さんによる
コメントを追加
get into download mode then hold volume down, power home and the phone should power off. If it won't power back on try holding power and volume down for like 20 sec, it may boot normally.
Boot into recovery power volume up and home and try clearing cache partition (wont delete your files)
then in recovery try factory date reset (will delete your files)
finally if all else fails flash the stock rom (make sure same version or newer than you are using can't go back) using odin
このアンサーは役に立ちましたか?
スコア 10
2 件のコメント:
THANK YOU SOO MUCH BUDDY !!
You saved my device ! i was worried BADLY ! I was trying to install new firmware on my android ;/ thanks anyways buddy :) God Bless you :)
さんによる
vol up+vol down+power+home not work for me, power+home also not and if i go to vol up or down+home+power phone goes to Odin mode, i need to factory reset coz i forgot lock pattern. please help if possible.
さんによる
コメントを追加
Hold Power + Home 15 seconds (Hard reset)
Hold Voume Up + Power + Home until recovery boots.
If this doesn't boot recovery mode and your phone is stock and untouched take it back to Samsung.
If you've flashed CFW/repaired it you're going to have to put it into download mode (like you were stuck on) and flash OFW via Odin.,
このアンサーは役に立ちましたか?
スコア 6
1件のコメント:
You are like God for me you saved me from my parents as I do this is mistake
さんによる
コメントを追加
Thanks a ton. Verified! It Works! Press all the buttons Vol up + Vol Down + Home + Power and hold them!
このアンサーは役に立ちましたか?
スコア 6
2 件のコメント:
Thank you sir
it s work. do it Valium UP and Down , home , and power key for five seconds . its work. thank god and thank you
さんによる
It worked for me. Thank you so much :)
さんによる
コメントを追加
https://www.youtube.com/watch?v=bii27UQY...
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
When I do all 3 it go to maintenance boot mode
さんによる
コメントを追加
Try this.
Press and hold together "power button + volume up + volume down + home button" for about 1 minute and your phone will reboot to nomal.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
When mine reboots it is in another language. How do I change this??
さんによる
Thank you sir
さんによる
Its not working for me
さんによる
Hi, sorry for late reply guys.
Sometimes it takes more time and need to press and hold for about 1 minute.
If this does not work then wait for your battery to drain completely or bring it to your local technician.
さんによる
コメントを追加
ive got a samsug j6 can someone tell me how to fix it
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I yanked the battery out of my Note 2 when it did that. Then opened up Safe Mode by holding volume down as it powered up and removed some files that possibly were corrupt
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I yanked the battery out of my Note 2 Then restarted my phone in Safe Mode and uninstalled some apps I downloaded from Google Play that had embedded malware and its been ok since.
さんによる
can anybody help me please?
さんによる
i was trying to download iodine apps for my samsung galaxy s6edge plus but i cant download it
さんによる
コメントを追加
So sometime this type of situations occurred. Just Install a firmware to your phone. Flash with Odin. But it may reset your phone!!!. After you phone will work properly. Be sure a right firm to your phone. 100% guaranteed. If you have any or queries. Please email me at vineil91@gmail.com. Best of luck... :) :) :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi i cant get any of the above to work?help pls
さんによる
コメントを追加
I know this board is old, but I'm having this problem but none of these options work. I can get to the blue downloading screen, but when I push the button combinations on that screen it just goes black and does not boot up.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
So does mine do you know how to fix it?
さんによる
I had to repeat the process a few times before the volume down to restart phone option brought up the black and white Galaxy S6 screen to restart. However, now it keeps looping that screen and not actually rebooting. Keep at it!
さんによる
Hold the power and home button together for 15 seconds
さんによる
コメントを追加
Still stuck. Tried every example that was given on this page. Took the pbone back to the Sprint store where it was originally purchased from only to find that the techs there didn't know how to fix it. So now, Im just sitting on a $800 device that won't power on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
hajera さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 25
過去 30 日: 73
今までの合計 179,265
