メインコンテンツにスキップ
iMac G4 17インチ 1.25 GHzモデル M9168LA 2003年発売のPowerMac 6,1です。
superdrive, hard drive and memory replace and upgrade
Has anyone attempted to take apart the iMac G4 17" 1 Ghz model. My DVD drive died and I figured while it is open upgrade everything I can. I have spare 1GB DIMM ram, spare 250 GB Hard drive and spare DVD drive, also that thermal paste. Any advice will be helpful, and if anyone has a step by step guide with pictures will also be appreciated.
Thank you.
Update
The upgrade went flawlessly, the machine is performing better than before.
FYI to install a OEM DVD/CD burner you must remove the entire plastic faceplate of the drive case.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Here's a 24 page instruction guide on the optical and hard drive replacement. This is one of the most difficult machines to work on that Apple ever made so take your time: http://www.faqintosh.com/risorse/en/guid...
Make sure you have the correct RAM, ATA/IDE hard drive and optical that will work.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Beat me again--here is an additional link to help. + Ralph
http://www.xlr8yourmac.com/systems/iMac_...
さんによる
コメントを追加
回答を追加する
Dinowarrior18 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 6,028
