メインコンテンツにスキップ
締切られた回答
LCD black after digitizer replacement?
LCD was working prior to replacement. Home button works, power button works, Siri comes on, can even hear picture taken when pushing the two at the same time, but the LCD is black/blank. No dim logo, nothing. I've plugged and unplugged the connectors several times with no change. LCD doesn't appear to be cracked or broken from removal, but could it still have been damaged without visual proof? I've tried hard reset, would a restore thru iTunes do any good? Please help! Thx
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Have you unplugged the lcd while it was displaying? In that case you might have damaged your motherboard. The iPad Mini is in many ways a very delicate device. Working on mini's, always power down, unplug battery and only then unplug lcd and digi.
It is common with iPads that you have to soft reset to get the back light working after repair. If that doesn't solve your problem, try changing the lcd. If that doesn't fix it, you damaged your mobo, probably because of disconnecting the lcd with image still displaying, or ipad still powered on.
It's possible to fix this, but you'll need to find a place that has an IR-solder station to replace IC's on the motherboard.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No the battery was actually dead when I started in it. But I unplugged it first anyway before unplugging anything else. I've ordered another LCD so I'll give that a shot. The LCD was a booger to get off the shield underneath it so maybe I did something to it. Idk. Thanks for the help
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 375
