メインコンテンツにスキップ
Wii Uはハンドヘルドデバイスとペアになったゲームコンソールです。ユーザーは、GamePadでゲームをすることもできます。コンソールの修理は簡単で、デバイスはほとんどがモジュラーです。
191回答 すべてを表示
締切られた回答
Replace Wii U Gamepad Screen?
So I have a few questions on the Wii U gamepad screen?
1) How could I tell if I'm buying the right model screen for the gamepad (since I heard the wrong model can cause the screen to flip upside-down)?
2) Do I need to replace both the digitizer and LCD screen?
3) Is it cheaper to replace the screen myself of pay for the expired warranty to have Nintendo replace/fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I had my GamePad's screen stop working through water damage, and I succesfully replaced it. I have never heard of buying the wrong model of screen, since mine worked fine. I suggest buying a digitizer with it, since the two are glued together. If you can (I didn't look too hard) you should buy a new bezel, since that's actually glued to the digitzer and it's a pain to take off, though it can be (and was) done. You'll also need Y1 and Y0 tri-wing screwdrivers, as well as #0 and #00 Philips ones. The digitizer and screen are about $20 from eBay. In all, even with my mess-ups from doing it the first time - be sure to put the cables the right way - the replacement only took about 45 minutes.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 254
