How to replace panel & how to repair jack for headphones
my phone was not able to receive the voice clearly who spoke from other side can u fix it plzzzzzzzzzz
この質問は役に立ちましたか?
この質問は役に立ちましたか?
headphone jack on the k850i??
this device has no such thing - it has a fast port connector.
if the fast port connector didn't work - clean it.
most SE devices i had with fast port failures were dirty or hat a nice verdigris "layer" on it - clean it carefully, do not use any fluids except isopropyl alcohol (>90%) - and even then - remove the battery!
you can use an old toothbrush for the cleaning job (sure - a new one would work too - but don't use it afterwards for your teeth - it might taste a little bit "funny" ;-) )
このアンサーは役に立ちましたか?
Hello I want to work for the phone flash k850i
このアンサーは役に立ちましたか?
Do you have a program to flash his work
just by what ??
just by what ??????
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 1,121
