Why my iPhone is beeping?
Hello all,
so the iPhone 5c of my wife has fallen on the ground.
Screen is black. I was afraid to lose the data inside so i tried put it into iTunes. Obviously, iTunes recognizes the device IF the device is turned on, so no chance at this step.
I tried to put it into wall charger and started vibrate as crazy( like a second of vibration every 3 seconds or so). so i opened it and disconnected the battery. I left it disconnected for a couple of days because fixing is not my primary occupation.
I came back on it trying to reconnect the battery. Now it makes a single beep each 5or6 seconds. Screen still black. Visually it doesn't seems to be damaged, but somewhere i read about beep codes....I guess it's a motherboard issue. Can anyone helps me find the problem? i know the logic board is about 150/160 dollars or so. That's why I would like to be sure of the problem before buying the replacement.
Many thanks in advance, and good fixes
この質問は役に立ちましたか?
