メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
How to remove the battery in the iPhone 5/5C/5S easily?
I have seen many tutorials online on how to replace the battery, but it doesn't show how to remove the battery itself easily.
Plastic pry tools and spudgers break, metal pry tools puncture the battery, hair dryers don't soften the adhesive enough, dental floss breaks, and the factory pull tabs snaps.
Has anyone here found a solution to removing the battery of the iPhone 5/5C/5S easily, with no hassle and no risk of damage (if done correctly)?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
iPhone 5 batteries are relatively easy to remove, as the adhesion is no where near as strong as the 5C and 5S battery adhesive.
A simple spudger under the left side of the battery is enough to remove them, never do it by the logic board as this can cause pry damage.
As for the 5C and 5S, you have to pull the tabs real slow so they don't tear, pull them at an angle towards the edge of the housing, and not straight up, you then need to go around the battery, once past the corner of the battery, it's usually smooth sailing from there.
Should the tabs snap, there isn't a majorly easy way that I know of to remove it, I've tried a heat gun on the back, but for me, doesn't really make it that much looser, and you can't do it too much on the 5C due to the plastic housing.
I've heard of people using plastic cards to do it.
Dental floss is pretty weak, you could try molybdenum wire, as this is extremely thin, yet pretty strong, and is used for removing the adhesive under the glass screen on samsungs and iPhones, I've never heard of anyone doing it that way though, you'd probably have to be really careful near the lock flex etc.
so if you tried that and it was successful, let me know.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
PowerLemons さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,018
