メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
Stuck in a boot loop
Mine is stuck in a boot loop and I can't get to recovery mode by pushing the power and volume button, I can only get to download mode. I tried flashing ROM as described by XDA Developers, and it said it passed, but it's still in the boot loop.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント:
Mine also has a boot loop Too and it's unusable
さんによる
コメントを追加
1 件の回答
It sounds like your phone is in a boot loop and you're unable to get it to boot into recovery mode. This can be a frustrating problem, but there are a few things you can try to fix it.
Method 1: Force reboot
The first thing you can try is to force reboot your phone. This will usually clear any temporary glitches that may be causing the boot loop. To force reboot your phone, follow these steps:
  1. Press and hold the power button for about 10 seconds.
  2. Your phone will power off and then power back on.
Once your phone has rebooted, try to boot into recovery mode. If you can boot into recovery mode, you can then try to flash the ROM again.
Method 2: Flash the ROM using a different tool
If you can't boot into recovery mode, you can try flashing the ROM using a different tool. There are a number of different tools available, so you'll need to find one that is compatible with your phone. Once you have found a tool, follow the instructions to flash the ROM.
Method 3: Take your phone to a repair shop
If you've tried the above methods and you're still having problems, you may need to take your phone to a repair shop. A repair shop will be able to diagnose the problem and fix it for you.
I hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lewie2s さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 858
