T-coil uses on uniden
What is the t-coil used for?
この質問は役に立ちましたか?
It has to do with hearing aides. From what I understand, it allows people with hearing aids to use a magnetic signal instead of just sound to communicate with their hearing aides. Hope this helps.
このアンサーは役に立ちましたか?
My moms uniden cordless phones won't keep charge? is something in menu setup wrong...
このアンサーは役に立ちましたか?
It could be the battery. The older style batterys don’t last long and even though they show a good charge won’t last more than a minute
過去 24時間: 1
過去 7 日: 12
過去 30 日: 55
今までの合計 8,203
2 件のコメント
The answer by" Knows a little" with the website http://www.hearing-aids-wizard.com/t-coi... leads to an Asian !!%@ site. You may, or may not, want to fix this. I hope you will!!
Bennie さんによる
When I go to dial the phone, it beeps 4 times before I hear a dial tone. How can I removed the 4 beeps?
diana5601 さんによる
