Why does my Cell phone work erratically?
My cell phone has been working erratically and the battery no longer keeps charge.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
This is a battery issue for sure, usually when phone batteries can't keep charge they can get extremely hot charging and cause more damage to your phone! So do yourself a favor and replace the battery asap! Don't worry though, there are replacement guides here. These guides provide clean and straightforward pictures with captions and markings to guide you through the process. It's very easy! Good luck!
このアンサーは役に立ちましたか?
I'm up set and need this fuxed asap
i have changed the battery and still running hot
also
how do i make sure all the right programs are installed the right way
this is a new phone about a month old
and why
no sd card
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 328
