radiator hose connection nipple broken off.
On the top of the radiator is a small plastic connection of which a hose connecting the radiator with the coolant expansion tank. this hose is small and is connected above a larger hose to a small plastic nipple the hose is connected to and clamped on. the neck of the nipple broke off, leaving a hole where coolant pours out. Is this a separate part or can it be fixed?
この質問は役に立ちましたか?
7 件のコメント
The Radiator hose connection nipple broken off Question is for 2001 Mercedes ML320. Fluids are leaking, I need help PEOPLE!
bethellowell さんによる
Les, said its a one man Job and his response to mine was great!! However it takes atleast some previous experience wrenching or repairing a vehicle. And unless you have a shitload of tools lying around you may run up to local auto parts for a couple sockets or a metric odd man size. It took me 45 minutes to an hour just to tear it down nicely and keep all my nuts and bolts in order "however my screws could be loose" If I were to say a half hour for whole job. But stevies youtube video on this ml320 radiator change, well lets just say the brother saved me some cash for my alluminum heads on the small block chevy 350 im playing with. Not much for imported Im american Muscle Car fan, But im not racist about cars. I can always appreciate a good vehicle no matter shape, size, or color.
oh yeah and it took me well over an hour putting back together and thats with fluid top offs and bleeding of the system. TO Bleed: Take resivoir cap off and turn car on and let it heat up. "comon my peeps"
sash man さんによる
I have same nipple break problem..do not know if it will work, but I drilled 5/16th hole into spot where nipple was broken off, tapped with 1/8 npt tap, then screwed in a 1/8" npt x 5/16 " barb fitting..not as tight as I would like but snug..i then took it out and wrapped yellow teflon tape around thread then reinserted..will see if it holds up and is leak-proof.
i am concerned about driving on long 2-3 thousand mile trips..so I am giving the grommet idea some thought..My thought is to put same 5/16th x 1/8" npt fitting in barb first ..then if tight enough, the barb should keep it from coming out of grommet under pressure..Maybe my threaded connection will work though. What causes me worry is that the black nylon end of radiator is barely thicker than 1/16th inch..if it were 1/8th or larger, i would feel more secure about it working
pat yak さんによる
@patcat How has this fix worked for you as of far? I have a broken nipple too and was thinking of doing this exact fix on my vehicle. I honestly don't see why it wouldnt workout.. Let me know!
demonfeuer さんによる
You can buy just the nipple very cheap
John Daily さんによる
2件以上のコメントを表示
