will not turn on after having a power outage
my workforce will not power up after a power outage.
it has a fuse on the main board that seems to blow easily , if it's completely dead that's probably it , a factory repair costs more than a new printer, don't use the cleaning cycle on these more than once it uses a lot of ink and then clogs the nozzles worse than before
このアンサーは役に立ちましたか?
How do I find the main board & fuse
Thanks!but where can I find the fuses ?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 21
今までの合計 5,103
1件のコメント
It may be a problem with your power cord or outlet, if it is plugged into a power strip or similar secondary power source try plugging it directly into the wall.
Tyler Momberger さんによる
