How to added transmission oil
how to added transmission oil
この質問は役に立ちましたか?
boris, not an easy thing to do. Going to be tough without a lift or a pit. There is a fill plug on the back of the transmission. Remove the plug and put a finger in the hole. If it doesn't come out with fluid on it, it's low. To refill, fill it up in the hole until it comes out. Remember to use CVT fluid only
このアンサーは役に立ちましたか?
It should be up to the bottom of the hole somewhere around 100 degrees Fahrenheit.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 13
過去 30 日: 38
今までの合計 17,307
