Changing logic board advice
Wife forgot icloud password and doesn't have the email/credit cart used before and now its locked out. If i change the logic board will i be able to use the ipad like new?
Hi Scott.
Yes as long as the motherboard your replacing it with is not iCloud locked too.
Have you not tried re setting the password?
If you still have access to the e mail registered to the apple id you can e mail yourself a link to reset here.
www.iforgot.apple.com
If that fails contact apple support I've always found them very helpful & have always helped my clients reset their passwords as long as you can satisfy them its your apple id.
you can contact them here
https://www.apple.com/uk/support/icloud/...
hope this helps a bit.
このアンサーは役に立ちましたか?
Thank you. Looks like she figured out log in info. I appreciate the help!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 68
