メインコンテンツにスキップ
The HTC Desire is the first smartphone of the Desire series developed by HTC.
37回答 すべてを表示
締切られた回答
Problems with battery, backlight and screen
I need some help with my HTC desire 300
  • The touch screen doesn't work on a small side of the screen
  • in certain positions the backlight doesnt work. when i bend my phone it seems to work and when certain pressure is applied to the back of the phone
  • my phone is also no long charging and started shutting down randomly
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sounds typical of water damage, but it could be a number of things. A loose or damaged flex cable might cause some of the problems, but if I was working on it I'd start by looking for signs of moisture on the motherboard. Further diagnosis would require opening the phone and inspecting it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 235
