メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
just vibrates when plugged in
ok so I had a screen problems(aka crack screenS) I have a BRAND NEW screen and was installin but after wards I plugged in the phone to have it vibrate every 10 seconds and never stop... what the heck causes this??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
It was the mother board on the phone I took it to a shop and had them look into it they tried all kinds of mixtures of new parts.. thanks for all the help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if you have no display and the vibrate constantly going then you have an installation problem..it's pretty easy to damage these little cables or bend them and break the threads inside the cable..then you have another broken screen. There may be other problems which is why you have the constant vibrate, it may be the installation, whatever damaged the screen in the first place or an incompatible screen. I'd redo the repair, checking all your connections as you go, fully charge the battery and see what happens/check if no display that iTunes recognises it. If you've done all these things and the problem persists then I'd order another screen and be more careful…then when you've got a working display you can see what the problem is.
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
it does this without the screen installed... before I added it to the phone I left it for 4 hours and it still does it.. and I continued with the screen install and waited another 2 it still hasn't worked..
さんによる
you checked the vibrate switch is off? redone the screen? if you plug in to iTunes how full is battery. it may be a dead battery..they won't charge
さんによる
computer wont recognize the phone says there is problem connecting
さんによる
you need to test the charge on the battery with a multi-meter, if the charge is below 2.2mAh it will not charge and you get a boot loop/constant vibrate, not recognised by iTunes. if that is the case you need a new battery and the new screen.
さんによる
how do I test the battery with multi meter I know how to use one but not on something with this type of connection... btw thank you for your time in helping me
さんによる
3件以上のコメントを表示
コメントを追加
Sounds like the backlight or display is not turning on. Try another screen or your old one first.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
YO my iphone is disabled and i want to connect to itunes but when i connect to my laptop it just vibrates 3 times and never charges or detect the laptop
さんによる
コメントを追加
回答を追加する
SALT さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 22
今までの合計 1,552
