メインコンテンツにスキップ
These repair guides are for a 2007-2012 Jeep Wrangler (JK) Sport, Sahara, Rubicon and Unlimited Editions.
22回答 すべてを表示
trying to jump battery lights flash and horn blows
tyring to jump battery horn blows and lights flash
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
4 件のコメント
What makes headlights buzzard randomly go off only when headlights are on
さんによる
It's on a 2001 jeep wrangler
さんによる
Your alarm?
This happened to me in my Chev van.
When my jeep alarm goes off, the headlights flash. Wranger 2008
さんによる
Toyota Sienna 2012. Once you start to jump the vehicle or replace the battery, the horn will start honking. Just walk over with the key and unlock the vehicle. it should stop honking and reset the security system
さんによる
コメントを追加
4件の回答
選択されたソリューション
It's probably your alarm system that's going off. When the battery died, the car's alarm system assumed that someone is tampering with the battery or had disconnected it in order to break into the car. Here's what you can do hook up the jumper cables. The horn will start to blow. As soon as it does, using the key fob, lock and then unlock the doors or basically whatever you usually do to shut off your alarm. once you've disabled the alarm go ahead and try to start up.
このアンサーは役に立ちましたか?
スコア 19
22 件のコメント:
It worked like a charm. It happened once before, but so long ago I forgot how to stop it. My remote doesn't work but locking and unlocking the doors a couple of times fixed the problem.
さんによる
My fob for my 2004 Lincoln Towncar also did not work. After doing a reconditioning recharge with a C-Tek Charger (24-ish hours) I connected the battery loosely which started the horn blowing again. Ran to the driver door and used the key to lock and unlock a time or two. Horn stopped. Car wouldn’t crank until I tightened the battery cable clamps. So just a little Power was enough to start the horn blowing but not enough to start the car.
Thanks for this answer. Saved me a tow and a service charge at a minimum.
さんによる
thank you Richard and Rob. that worked 0n my 2003 Honda pilot. Mike
さんによる
Thank you, this worked wonderfully! What do you think could have caused this?
さんによる
I have a viper alarm system on my car. Tried to upgrade my horn on my van tested it worked fine as a horn but alarm sound stopped working except on my fob. Connected the old horn back and still the same issue. The alarm system works except the the van makes no sound at all. Remote start. Locks side lights flash but no sound?? Is a fuse blown?
さんによる
17件以上のコメントを表示
コメントを追加
You can also put your key in the door and lock and unlock a couple of times. Worked great!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How do you use your key to unlock the door in when it's in the ignition?
さんによる
コメントを追加
Another way to stop the horn from blowing, open fuse box and remove horn fuse. Connect battery , start car and reinstall fuse. Problem solved
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When I was trying to remove cable of negative terminal of battery I forgot to lock car by remote then suddenly I touch negative cable to terminal of battery and looked car but it different sound but after charging battery when I first connect positive and then negative it started blowing siren..so I didn't connect negative terminal because when I m trying to connect negative terminal it started siren like as a someone trying to open door with different keys or say stealing..how can I resolve this problem?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jgwright54 さん、ありがとうございました!
統計データ:
過去 24時間: 42
過去 7 日: 242
過去 30 日: 1,160
今までの合計 183,090
