My laptop wont boot up!
I push the power button and it just flashs 5 times then stops the laptop dosnt boot the screen dosnt even turn on an also the light bolb icon at the bottom flashs too.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
jack, since the blue lights blinks 5 times then stops after the power button is pressed, it is an indication that the battery has drained out and unable to receive power from AC adapter, you may check by pluging the AC adapter to another working wall outlet. If the issue persist you need to replace the AC adapter. You may also perform the below mentioned power reset steps before replacing the AC adapter.
You may perform a power reset by unplugging the AC adapter from notebook, Turn the notebook over to remove the battery. Turn the notebook back over and open it, Hold down the power button for 30 seconds, then release the power button, Turn the notebook back over and slide the battery back into place, Slide the lock tab back into the lock position, Turn over the notebook one last time and plug in your AC adapter, Turn on your notebook. from here
このアンサーは役に立ちましたか?
You save my life... I was thinking that my laptop died.. before that bad experience between changing Intel Optane to m.2 ssd and not recognizing my 1tb hdd, loool, thanks!
過去 24時間: 4
過去 7 日: 20
過去 30 日: 100
今までの合計 6,419
1件のコメント
thank u soo much for that
jack さんによる
