メインコンテンツにスキップ
A 17" LCD Display for an Apple computer produced between 2001 and 2004.
7回答 すべてを表示
My mac display is dimming!
My mac display is at the highest brightness setting. It is about 5 years old, and I'm wondering if there is a bulb or something wearing out. If so, can it be replaced?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Can you comment on the model of the computer?
さんによる
It is a desktop display. An Apple Studio 17 LCD that came with the original dual G5
さんによる
if you need help taking it apart, i do have a teardown posted for this exact display.
さんによる
コメントを追加
5件の回答
ベストアンサー
The inverter board is the part which needs to be replaced, a search finds them running about $130 dollars.
If you want an Apple ADC display, it may be less expensive and less work to find a replacement display on eBay or Craigslist. You might even find a larger Apple display for the cost of the repair parts.
You could also consider buying a new LCD - there are many good 3rd party options in the $130 range, and a new device, with newer technology, will probably outlast your G5...
I found an excellent take-apart at: http://mac-guild.org/display-repair.html
The class-action settlement probably no longer applies, as this model has long since been put on the obsolete list, BTW.
Good Luck!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you David, you are right that it is time to get a new monitor, and truth be told, a new hard drive.
さんによる
コメントを追加
最も参考になった回答
It's very difficult to replace just the CFL bulb without damaging the rest of the display as you have to strip it completely down to pieces.
BTW you don't have to buy the complete cover, and or frame assembled once you get the old display apart on the back there's size and type information that will let you order a brand new replacement LCD online depending upon the size a new LCD should cost less than $100 for a 12 or 13" CFL probably what's in a machine that old.
N.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
What type of mac display is it? most likely the display itself is going bad and the lcd needs to be replaced. it happens to the best of em. :(
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It's a 17" apple studio display (ADC)
さんによる
コメントを追加
most LCD's will last about 60,000 hours beecase of there backlights, and if your an avid computer user it's about time for a new moniter anyways
checkout either this site or bestbuy to see if you can recycle it, I know that bestbuy will pay you to recycle your used electronics
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Open System Preferences
  • Click on Energy Saver
  • Click on Display
IN energy saver option un-check Slightly dim the display
Automatically reduce brightness
In display section
Automatically adjust brightness
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
clinegunk さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 3,942
