whered is the idle air control valve located
where is the idle air control valve located
この質問は役に立ちましたか?
この質問は役に立ちましたか?
deborahfoley70, you did not tell us what engine your Honda has. The Idle Air Control (IAC) is marked on the images posted.
Location on the 4cylinder engine is center rear
Location on the 6cylinder engine is left side of the engine
このアンサーは役に立ちましたか?
This is always located just aft of the throttle body intake. It will usually have a 2 wire cable going to it. This valve keeps the engine from stalling when the main throttle butterfly is closed.
このアンサーは役に立ちましたか?
Mounted underneath throttlebody with 2 Phillips head screws that be difficult to remove on high mileage vehicles
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 23
過去 30 日: 97
今までの合計 36,620
1件のコメント
Can tell me where it is located
vjohnson1165 さんによる
