メインコンテンツにスキップ
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202回答 すべてを表示
Removing demo software on HTC One M8
I got a demo unit (HTC One M8) through work. I have tried to restore this to work as a normal phone, but I was unable to do so. There is an app called Demo that I cant uninstall. The Developer mode can't be touched but USB debugging mode is on (when I connect it to my PC). I can't do a factory reset as the OK button is greyed out.
Any tips would be greatly appreciated
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
I baught one m8 with demo mode as impulse buy, didnt see this hidden in description. Demo cannot be deleted from settings as option is greyed out. I did have adb enabled though so I unlocked bootloader with HTC dev and rooted. Once custom rom was installed demo mode was gone.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
How do i do all this
さんによる
Yes, how to do that
さんによる
salamoalikom friends you can find all this in youtube just make how to unlocked bootloader and root my HTC one m8 . after ulocked and rooted you need to see an other video how to install a custom ROM in HTC one M8 thats what i do to resolve my problem .i hope that can help you . good luck.
さんによる
コメントを追加
Try doing a factory reset with the phone off, turn the phone on by holding the power button and the vol - button for around 4-5 sec. this should boot the phone into bootloader mode. in the bootloader menu go to either factory reset or recovery( don't remember how it's labeled but it will be one or the other) to navigate in bootloader mode use the vol + to go up vol - to go down and the power button is select.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
factory reset from bootloader menu will only return to demo mode when restarted. However if adb is enabled then you can HTC unlock and root. Install custom rom and demo is gone.
さんによる
How do you know if the adb is enable?
さんによる
Then I would flash stock HTC one M8 firmware (that is compatible and works with the phone fine) once the bootloader is unlocked which can be done instead of installing a custom ROM.
さんによる
コメントを追加
how to remove demo mode from my phone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
morten skaar さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 6
過去 30 日: 10
今までの合計 14,626
