My display screen glass is cracked. The display still works
The glass display screen is cracked from strapping it on a bike mount improperly. The display is fine and view-able. I would like to replace the glass. Is there a fix for this?
messingaroundnet , yes you can just replace the display window. you can either remove the back case by following this video and then remove the glass with a hot air source. Or you can try it this way.
このアンサーは役に立ちましたか?
Hi, does anyone know where can I buy the rear glass screen (not the LCD), I can't seem to locate the rear glass screen anywhere. If you have a link for a company who sells/ships to the UK I would be grateful. Thank you. Andy
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 2,307
