Computer will not post
Computer has power but will not go through POST process. I don't hear any beeps at all. Monitor says "Auto detect power saving mode." Monitor is working because I plugged it into a different computer.
A computer that will not post suggests two possible causes:
1) Bad motherboard;
2) Bad power supply.
I have made an assumption: that you have only one video connector on your system. If you have more than one, try connecting your monitor to other video connectors.
Also, you do not say if the fan starts when you attempt to start the system. It usually starts at high speed and then quiets down.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 8
今までの合計 160
It does not POST or your do not have any video? This just started or did anything happen to your computer? What have you tried?
oldturkey03 さんによる
