メインコンテンツにスキップ
This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
20回答 すべてを表示
Droidboot Provision OS screen
When tablet is turned on, it goes to a "Droidboot Provision OS" screen. Lists info on tablet; select; reboot ; a list of commands; last info, "Could not open /sys/devices/virtual/backlight". No buttons work except ON/OFF. What can I do? Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 16
3 件のコメント
have you tried a hard reset? hold power button aqnd volume down together fore 10seconds or so then do it again for 2-3 seconds
さんによる
how do i solve this problem my tablet is showing this massage 'google play store has juss stopped working, whenever i try to access any application' help please
tina
さんによる
How do I can return to fabric items?
Actually,when I do that,says that installer device ignored
I don't know what to do
Can you help me?
さんによる
コメントを追加
5件の回答
最も参考になった回答
Hi
download your firmware file from asus.com.
install fastboot on your computer.
use this command:
fastboot flash update pathOfDownloadedFirmwareFile
All of the your files in tablet will delete.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
ASUS provide zip file and when we run this command it says missing text files
さんによる
can you give more detailed information ?
さんによる
コメントを追加
Hi. My tab is Asus memo k011.
when I use this command:
this error appears:
C:\adb>fastboot flash update UL-K011-WW-3.1.23.172-user.zip
target reported max download size of 568967168 bytes
Invalid sparse file format at header magi
error: write_sparse_skip_chunk: don't care size 922051909 is not a multiple of t
he block size 4096
sending sparse 'update' (0 KB)...
he block size 4096
he block size 4096
OKAY [ 0.411s]
writing 'update'...
OKAY [ 0.650s]
finished. total time: 1.064s
what I do?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Mei tablet bringt das soeben was tun
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
the screen has stoppet can not be used
hej !
surf platan starter sen det går inte använda skärmen
mvh
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
forgot screen pattern of phone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
linda2222 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 37
今までの合計 21,124
