メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Phone overheating when camera is on
Hi,
I have a problem with my iPhone 5s. I dropped my iPhone and the screen was cracked. After the drop, my rear camera and flashlight stopped working. I thought if I replace the screen, the camera might start working again but no luck. If I try to turn them on, the top right corner of the phone gets extremely hot and I need to turn my phone off to stop the heat.
Anyone know what might be the problem and how to resolve that?
Thank you.
K.V
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Sometimes on electronics the thermal paste can get dried up. Sometimes it's best to open it up, re-paste the thermal, and put it back together. Although what i think is happening is the camera is stuck on permanently and that is causing the heat ups. Hope that helps!
The camera part on ebay is about 10$.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for your reply. The flashlight is also not working. Do you think when I replace my rear camera, then it all should be OK?
さんによる
コメントを追加
The camera and the flash light are correlated parts. If camera stops working, the flashlight doesn't work either. Therefore, fixing camera issue resolves the flash light. You can get the required part here. Check out similar vendors selling the same items at the most competitive price. This will benefit you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Keiro Vantsi さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,648
