Is there a place for a sim card?
There is a slot for a micro sd card, but I do not see a slot for a sim. Do I need to take the back off to access it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If your tablet supports it the sim card will be located on the same side of the tablet as the sd slot however not all tablets are made to support a sim card . This video shows how to change it out if its supported
https://www.youtube.com/watch?v=Iypr20hI...
Hope this helps
このアンサーは役に立ちましたか?
That video was useless.
Does a galaxy tab a sm-p550 have a sim slot
really this was useless
Hey Sara, it seems like you have a Samsung Galaxy Tab 3 7.0 P3210. This has no sim-card slot and is the Wi-Fi only tablet. The Samsung Galaxy Tab 3 7.0 P3200 has a slot.
-Let me know if this helps.
このアンサーは役に立ちましたか?
But, it's showing a message on the screen which reads "insert simcard"
Hi I have a Samsung A6, does this have a sim slot?
Hi Lillian I have gobii tablet does it support simcard
what about changing the battery of a samsung tab 3, mine is nolonger working well and i want to change it but its seeming impossible
このアンサーは役に立ちましたか?
Take it in to a Samsung shop or similar, and explain the issue, they should be able to replace the battery for you.
Just download firmware sm-t116nu in your tab and use your micro sd card slot to your sim
このアンサーは役に立ちましたか?
does that really work?
That is brilliant....If there is an adapter from sd to sim then why can't software make it work. I have not tried this but it sure does sound plausible to me. Kyle, you are a scary kid. Kudos. I'm not sure but I think I'll give it a whirl because although I don't seem to have an adapter I do however have a pulled sim slot and a soldering iron. The software I'll be trying is this one: https://firmware.gem-flash.com/index.php...
The sim card goes in a slot next to the memory card . If you don't have this then you don't have a phone facility
このアンサーは役に立ちましたか?
Hi
I have the t820 model with this double slot.
Does this mean my tablet is sim ready?
When I brought it 2 years ago the shop assistant said these tablets will take sim
I'm guessing I need to buy a new holder?
このアンサーは役に立ちましたか?
thats the same as mine. did yours come with the keyboard? its very helpful....
i got the sm-t820 also with the double slot but my holder is like yours with only the sd slot holder.. did you get a double holder and if so did it work? also my sd card just stopped working.. any suggestions??
I have a Samsung tab 3, would like to add this device to Verizon, right now has a sprint SIM card, how do I address the issue?
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 14
過去 30 日: 84
今までの合計 96,125
4 件のコメント
is ka file kaha pa hae sent gmail
Muhmmad Ali さんによる
Is there any way to have and insert sim card because I have the same tab like sarah
Johannes Rosario さんによる
what about Galaxy tab E T560 SIM card insurted are not paz gu
Waleed Khan さんによる
When I insert sim card into my Samsung Galaxy 3 it still says to enter a sim card..
Kandie Madsen さんによる
