メインコンテンツにスキップ
The third iteration of the 10.1 inch Galaxy Tab tablet.
126回答 すべてを表示
締切られた回答
Screen touches itself rapidly and repeatedly
Hi. I have a Galaxy Tab 3 10.1. The digitizer was coming loose from the case so that the home button was recessed. I put a little Goop along the bottom edge (I mean a small amount applied with a toothpick) and held it together until it would hold the seal by itself. Ever since then, the screen acts like I am pushing it all over the place, rapidly. It opens up apps by itself so fast that the clicking-sound sounds like a machine gun. I pulled the digitizer away from the screen and out of the case, then removed the Goop with a little rubbing alcohol (with the alcohol on a rag, not directly on the screen). It still clicks itself rapidly. Any ideas? Thank you in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
pinched cable or you got something on the digitizer ribbon
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 239
