メインコンテンツにスキップ
Appleは2880×1800ピクセル標準解像度でRetinaディスプレイを装備した新しいデバイスを発売しました。
3614回答 すべてを表示
締切られた回答
Apple Hardware Test Failure Code:4SNS/1/40000000:TGOP-82.125
Hello,
I have been struggling with a really laggy Macbook pro. I did a clean install of Mavericks, in hopes to resolve it, but no such luck. My problems have worsened. It doesn't play videos properly anymore and is overheating.
I ran the "Apple Harware Test" and got a failure notice, saying : 4SNS/1/40000000:TGOP-82.125
I tried finding this mistake online, but no such luck either.
It also tried using Disk utilities and verify the permissions of my HD, and could only find a minor bug, due to the fact that my printer isn't set up yet...
Please help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
What is the 820 number of your logic board? 820-3332 or 820-3787? It will be written on the board.
A few potential issues here.
a) Your machine is actually overheating because it is filled with dust. All Apple laptops and iMacs are designed in a way that allows dust to enter, but not to escape. Every machine on earth will eventually get clogged with dust, but Apples far worse than a Thinkpad for example. The retina is really really bad with it. Open it up and clean it, I am sure there will be a mountain of crap in there if this is the 2012 model.
b) On 820-3332 board, tin whiskers growing on Q5501 and Q5503 on the motherboard. If it is not actually overheating, it could think it is overheating due to sensor flaw, and tin whsikers on those are not uncommon. Check U5550 area as well.
My guess is on dust. Blow out the dust, clean up the fans, and you should be good to go. Extra points if you replace Apple's junk shin etsu thermal paste with some Tuniq TX-4, this will go back to being a beast in no time.
Good luck!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
4SNS - indicates a system sensor is not happy. TGOP - indicates it is the GPU temperature.
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 216
