メインコンテンツにスキップ
The eMac was an all-in-one G4-based Mac designed for the education market and released in April 2002. It was the last Mac to use a CRT display and was sold at a low price to schools and other institutions.
47回答 すべてを表示
Am I using the wrong ethernet cable?
when using an average ethernet cable,emac
won't recognize it.
Will the Belkin RJ45 FastCAT™ 5e Patch Cable, Snagless Molded Cable fix my problem?
Also, is there a way to upgrade the 1.1 usb ports with 2.0 usb?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
First thing you should do is just try any other ethernet cable, to rule out a bad cable. Ether cables are fairly delicate and shouldn't be bent too sharply. Are you seeing "No cable connected" in the Network control panel? If you still get this message with a different, known-good cable, then your Ether port might be toast, but first you should try zapping the PRAM, resetting the NVRAM, and booting to a different system, to rule out software.
If your port appears to have died (I've had this happen a few times) you can get a USB-Ethernet adapter like this one: http://eshop.macsales.com/item/Macally/A...
Of course, first check ifixit to see if they have something like it!
Zap PRAM: reboot while holding down command, option, P, R. Keep holding down till you hear 3 chimes.
Reset NVRAM: hold down command, option, the letter O, and F. You'll get a while screen with black text. Type "reset-nvram" and Return. Type "reset-all" at which point the computer will reboot automatically.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
NO and
NO
Re the cable, what are you connecting to, you may need a crossover cable?
このアンサーは役に立ちましたか?
スコア -1
5 件のコメント:
Macs since a long time back don't need crossover cables; they can sense what's needed and deal with it internally.
さんによる
A cross-over cable would be used to connect like devices (eg. 2 hosts, a desktop to a laptop). Straight-through cables are used to connect different devices, such as a host to a router.
You may want to check up on your answers before posting.
さんによる
Many recent Macs, including all Intel Macs, do not require crossover cables. See http://support.apple.com/kb/HT2274. As for this eMac, if it's ATI graphics or later, it does not require a crossover cable; they have Auto-MDIX, which automatically configures the ethernet connection. The OP does not say what they are trying to connect to, as you correctly point out, but one can presume it's a hub, switch, or router, as that's the most common scenario.
さんによる
Still, the probably scenario (unlike devices), a straight through, the most common type of ethernet cable, is the needed one.
さんによる
AKA a patch cable.
さんによる
コメントを追加
回答を追加する
Celeste さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 7
今までの合計 2,588
