メインコンテンツにスキップ
シンプルな35mmマニュアルフォーカス一眼レフカメラ。 型番X-370。
26回答 すべてを表示
Why am I seeing black after I take a picture?
When I go to take a picture I hear the shutter sound but all I see is black. I open up the film door and check there is a thin black sheet right behind the film that is not closing all the way. I have put new batteries in.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Your shutter is stuck. This has the side effect that the mirror will not return to its normal position, which blacks out the viewfinder.
Problems like these are not unusual in older cameras, and should be looked at by someone who's familiar with these old mechanical beasts. Avoid messing with the camera as you might make things worse - shutters are very delicate mechanisms. Keep in mind that spare parts are no longer readily available for these cameras.
EDIT:
Some research tells me that stuck shutters are a common problem with this particular camera.
There appear to be different causes for this problem. Sometimes, it appears to be a matter of "lack of exercise". One suggested solution is a gentle whack against the palm of the hand :) , another is the use of a fingernail to gently persuade the shutter to close completely - but be careful! In other cases, the problem seems to be caused by the camera's electrics, specifically, corrosion due to old leaking batteries. Check the inside of the battery compartment for corrosion, if you find any (greenish crud) have the camera cleaned and inspected - the corrosion may have propagated outside the battery compartment.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Marissa martinez さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 31
過去 30 日: 112
今までの合計 4,691
