メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Screw Size and Diagram
Hiya Everyone,
Hopefully someone will be able to help, basically I accidently knock my screws of my magnet board when repair my iPhone 5s. So now I don't know which screw goes where does anyone have a diagram that states the size of the screw or any advice on what to do
Thank you all.
Update
thank you guys, appreciate the help.
I have one other question I have a little rubber square and I'm not quite sure where its come out from and can not see it on the guide any ideas?
Thank you in advance
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
This rubber square comed from the microphone hole on the lower part of the phone. It's internal and protect the microphone from the dust.
https://images-na.ssl-images-amazon.com/...
さんによる
コメントを追加
4件の回答
ベストアンサー
Hi Sam,
Are you following an iFixit guide?
If not, go to that page, choose the guide that you need, and you will see that there are steps that indicate what screws go where, and their respective sizes. You will need an accurate measuring tool such as this caliper to measure the length, and trace each screw back to it's original place in the phone.
The most important screws to watch out for are those that hold the shield covering the screen connectors.
If in doubt, don't put any there. If you use a screw that's too long, it will rip through the board, potentially breaking traces within the board and causing very expensive damage.
Digital Caliperの画像
製品
Digital Caliper
$39.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It's the rubber for the mic. Goes between the headphone jack and the charge dock.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
That little rubber square goes at the bottom of the iPhone it holds a flat ribbon in place but it is not absolutely necessary
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Sam, the individual guides on here list the screw size with each step.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 20,972
