メインコンテンツにスキップ
GSM iPad 2は16、32、64GBの容量オプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1396。修理作業は複雑で、ヒート(熱)を当ててこじ開ける作業が必須です。
20回答 すべてを表示
Cellular data "issues" after we replaced digitizer
Hi, we replaced the digitizer on a customer's iPad 2 GSM model a few days ago. They came back complaining of their cellular data not working.
So what we see is that sometimes the cellular signal in the top left is simply missing. Upon deactivating, and reactivating cellular data we see it come back, with 5 dots and 3G service. It will stay like that, but when we try to use the cellular data to use safari, we get an error message saying "There is no remaining data on your current plan..."
The customer says he should automatically be getting his plan increased if he hits his limit, and that he should not even be at his limit.
If we try to increase the data plan ourselves on the ipad, it brings up the "Cellular Data Account" window, and gives an error "Connection Failed: The connection to the sever was lost."
At this point we can only click "OK" and the window dissapears, the ATT and signal strength icons disappear again. Now if we try to access a webpage, we get the error "Could not activate cellular data network. You are not subscribed to a cellular data service".
All we can do at this point is restart the whole cycle by deactivating, and reactivating cellular data in the settings.
Is it possible we damaged something to cause this, or is it simply an issue they need to take to AT&T?
Thanks in advance
-Sean
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Its been awhile, but we just had the client take it back to ATT and they resolved it there. Some kind of interruption to their service that didn't have anything to do with us after all that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sean M さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 124
