Brother Printer HL-2270DW Paper jam at front. HL-2140
The paper is jammed at the front. It is half torn off - cleanly. I cannot remove the cartridge.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The problem maybe the drums that drag the paper, the are worn up to the point they have no rugosity. Try to scratch them with your nails or with the tip of a screwdriver.
このアンサーは役に立ちましたか?
Normally, people get the paper jam error on their brother machine, when there is a piece of paper obstructing the printer parts. that’s why it can’t print your documents. so check your printer again carefully.
このアンサーは役に立ちましたか?
Thank you. In this case it was just a matter of removing the toner cartridge and freeing the paper, but I will remember your advice should this happen in the future.
With kind regards,
Kay
このアンサーは役に立ちましたか?
hello please follow this answer link to resolve your problem https://help.brother-usa.com/app/answers...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 3,966
