メインコンテンツにスキップ
MacBook、MacBook Pro、MacBook Air用のAC電源アダプタです。引っ張られても安全に外れる整列式の磁気コネクタを採用しています。第一世代 (2006-2012)のMagSafe充電器は、コネクタがやや太いL字型になっています。45W、60W、85Wの3種類があります。
65回答 すべてを表示
締切られた回答
Why is the magnet end failing to stay connected?
The magnet end of my MagSafe Adapter has stopped connecting consistently. I've cleaned out the socket (had a small metal bit get in the way once a couple of years ago) but this time no luck.
There seems to be quite a bit of play in it now, an older 2.66 GHz Intel Core i7 15" MBP.
Does the socket sometimes wear? or the pins start to loosen? or.... ??
And is there a fix?
Thanks for any help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
To find out if it is your plug or the socket, see if you can borrow a friend's MagSafe. If theirs works, you need a new cable. If it doesn't, it is your socket and you can narrow down what the problem is from there.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Ah, great thought on a differential diagnosis, like the docs say. Thanks, Jay, I can get at a second MagSafe tomorrow and will see what happens and report back.
Not sure which I'd prefer, though I guess getting a new MagSafe would be easier than figuring out how to fix the socket.... didn't see anything on that in a search here on iFixit... :}
さんによる
コメントを追加
The magnet are on the dc-in board in your computer, the magnet doesn't wear out over time. is the metal piece still attached to the end of your charger? sound like you need a new charger.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thanks, Sunny. The magnet is still there for sure, and feels strong. Somehow the connection inside is what's gotten flaky. Have you ever run into the pins loosening, for example?
さんによる
i cant say i have the charging circuit is build really strong. i guess it can happen. if you can take videos or pictures i will have a better idea what you are deal with.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 12
今までの合計 162
