Parking light and a/c system
parking light not working and a/c system not working. fuse is normal. what is the problem
Make sure that you have enough battery in the car cause sometimes if you dont have enough battery in the car it might disable features to save battery.
and bring it to a repair shop and tell them to look behind the ac and by the lights for faulty wires
hope this helps
このアンサーは役に立ちましたか?
and also make sure that you have a new bulb in the light
ac doesnt blow cold air. The fan works and when the a/c control panel switch is pressed, the light turns on but a/c does not engage and no cold air
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 552
