メインコンテンツにスキップ
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
100回答 すべてを表示
Why does my screen stay black?
dear fixers,
I recently got a Galaxy Tab S but the screen stays black.
I do feel vibrations and hear sounds from the machine.
The tablet hasnt fell or anything like that.
Anybody has experience with this problem, or can anybody tell me how to fix this myself?
Kind regards,
Soester
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
コメントを追加
3件の回答
try to reset your phone
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Did everything like holding the powerbutton + holding the - volume, i feel it fibrating but screen doesn't respond to anything.
さんによる
Although when i repeatedly hold the powerbutton and the - volume. The blackscreen give a white flinch
さんによる
コメントを追加
Most likely the ribbon cable for your screen might have come off the connection. My tablet is currently doing the same thing, so I am going to take it apart and check it out and try re-connecting it. I'll let you know how that goes.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
So as I mentioned about the ribbon cable. I took it apart and disconnected and then reconnected the ribbon cables for the screen and powered it back on and works perfectly.
さんによる
コメントを追加
If the screen ribbon Cable doesn't fix it. Check the cable with 5 wires going to battery it's in the center in between the batteries. Disconnect it leave it off for 10 seconds reconnect it. Then power on while holding the volume button and then reboot normal.
It's some &&^&@@ up bug on this tablet which sucks because otherwise it's an amazing machine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Soester さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 15
今までの合計 3,354
