Technical support why keurig wont work
Makes real loud noise and takes awhile to brew. when it brews just half a cup is brewed.
Hey joyce, the common fix for such issues is following the "de-scaling" instructions provided by Keurig themselves.
-Let me know how it goes.
-Please accept this as the answer if it answered your question.
このアンサーは役に立ちましたか?
I had the same problem with my Keurig.
It was clogged
What i did to fix it was i grabbed an air pump and pumped air through the water pipe to get all of that water that had been sitting there and that was clogging the Keurig.
After getting all of the water out fill some cups (without K-Cup) to make sure it works
このアンサーは役に立ちましたか?
Our Keuriģ coffee maker won't turn on. It's like it isn't getting electricity. Do you have any suggestions?
I have a Kureg 2.0 I followed the hack, to have the choice of using any cartage I wanted to. (I cut the green wire ) I also cut the black wire in the lid, allowing the different sizes of cups. Now when I plug it in, all I get is a week icon (start button) on the screen, pushing it does nothing. Any help would be appreciated. I NEED A CUP OF COFFEE !!! my E-mail is jonathan_tucker@junbo.com. Thanks for any help yu can give me.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 823
